PowerSteering Pump Tips
Old Feb 8, 2008 | 02:14 PM
CantStopTheFox...'s Avatar
CantStopTheFox...
Default PowerSteering Pump Tips
My Return Hose blew off my pump....the nut is still attached, but the tube flew out.
I tried to slide it back in,but when I turned the wheel it blew off again...
Napa said they will try to repair it, but either way.....I was wondering if anyone had any tips for bleeding the system?
Old Feb 8, 2008 | 03:12 PM
flyinghigh2k8's Avatar
flyinghigh2k8
Default RE: PowerSteering Pump Tips
I had the same problem. Me and my friend ****ed with it for about 2 hours and finally got it to stay on.
Old Feb 8, 2008 | 04:11 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
manual rack...
Old Feb 8, 2008 | 04:25 PM
c4king's Avatar
c4king
to correctly bleed it you will need to jack the front of car off ground, (both wheels off ground) then turn from side to side, dont hold at end of turn to long or the same thing might happen! but you pump is create to much presure the valve in your presure fitting might be sticking closed is why you line is blowing off..
jwog666
Dec 27, 2021 08:09 PM
Bokeo
Oct 10, 2015 08:28 PM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
mrappe
Sep 26, 2015 10:16 AM
