getting intake off
Old Mar 29, 2005 | 11:53 PM
silver91gt's Avatar
silver91gt
Default getting intake off
I used ultra blue gasket maker with my felpro gaskets and now I can't get my lower intake off.
do you guys have any tricks.
I tried prying against the valve covers, but it just started bending them.
I don't want to hit it with a hammer either, I also tried prying it from the intake ports and it made a dent in the runner, so I stopped that.
any help is appreciated.
Old Mar 30, 2005 | 12:25 AM
silver91gt's Avatar
silver91gt
Default RE: getting intake off
what, none of you had this problem be4?
Old Mar 30, 2005 | 12:31 AM
Dan89lx's Avatar
Dan89lx
take off the thermostat housing and stick a bar in the intake and pry easily
Old Mar 30, 2005 | 12:43 AM
fats429's Avatar
fats429
ORIGINAL: Dan89lx
that works or just grab the t-stat houseing and just lift stright up with two hands . as soon as you break the seal the rest will come off easy . next time olny use RTV on the front and back in place of the corks . the upper plemtum to lower intake gasket is set toalty dry B/W
just mussle it it is not like a weld good luck
Old Mar 30, 2005 | 02:40 PM
roundman's Avatar
roundman
you could also make a thin wood wedge and drive it carefully between the block and the intake at the front of the intake until the seal of the silicone breaks free.
Old Mar 30, 2005 | 02:44 PM
Derf00's Avatar
Derf00
Gentleman's Relish
You could also take a single blade razor and gently tap it into the seam. Do this where ever you have access. Will make it easier to pry off.
Old Mar 30, 2005 | 03:33 PM
vfast's Avatar
vfast
I ♥ Acer
I just use a painter scraper taping it
Old Mar 31, 2005 | 12:32 AM
silver91gt's Avatar
silver91gt
ORIGINAL: fats429
ORIGINAL: Dan89lx
my felpro gaskets come with rubber front and back gaskets, I use those covered with silicone.
I don't trust cork gaskets, they don't last.
I also noticed when I took the upper off the back 4 ports were pretty wet with fuel and oil, what could cause this?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jwog666
Dec 27, 2021 08:09 PM
daltron
Apr 28, 2016 08:10 PM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
