question about the two pipes running along my lower manifold
Old Feb 10, 2008 | 10:50 PM
93StreetFox's Avatar
93StreetFox
Default question about the two pipes running along my lower manifold
theres a rubber hose that spouts off of the top of em, i forgot where i unhooked it from
Old Feb 10, 2008 | 10:59 PM
Mustangkiler's Avatar
Mustangkiler
Default RE: question about the two pipes running along my lower manifold
Usually if your talking about the passenger side theres two plastic lines that run back to the heater core, there rubber on each end, side towards the firewall goes to the heater core and other ends one goes into the intake manifold and intoe bypass hose by the waterpump at least thats how iti s on my 94 Thats the only thingi can think that you could be talking about.
Old Feb 11, 2008 | 08:13 PM
bamaroxz's Avatar
bamaroxz
The hose you are discribing might go to your TB spacer if it comes off the top of the tubes kinda by the oil fill tube.
Old Feb 11, 2008 | 09:15 PM
93StreetFox
yeah thats the one, but i have the cobra intake now, so it must go somewhere else right?
Old Feb 11, 2008 | 11:00 PM
BLK89GT's Avatar
BLK89GT
just cause you have a cobra intake shouldnt change where the hose goes into the tb spacer.
Old Feb 12, 2008 | 12:34 AM
93StreetFox
thats what i thought too, until someone else told me another hose goes there instead
Old Feb 15, 2008 | 07:42 AM
bamaroxz's Avatar
bamaroxz
Can you post some pics? There are two small hoses (smaller than the other hoses from the tubes to your heater core, water pump) about 3/8", small like the size of a fuel line. One goes in the front of the spacer from the tubes top outlet and the other comes out the backside of the spacer. Hope that helps.
Old Feb 15, 2008 | 07:47 AM
bamaroxz's Avatar
bamaroxz
https://mustangforums.com/m_563238/tm.htm
Look at this link, you'll see the throttle body (tb)spacer with the hoses from the tubes.
Old Feb 15, 2008 | 12:57 PM
SD_LX_5.0's Avatar
SD_LX_5.0
If you have the newer remake of the cobra intake (like the one in summit's catalog) then it does not use an EGR/throttle body spacer and you need to either plug the line or just run the two together.
On the cobra the neck of the intake where the TB connects is just longer thats why it doesn't use one.
drfister
May 3, 2018 10:38 PM
spectreman
Mar 31, 2016 09:26 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
Soldier GT
Aug 12, 2015 03:46 PM
ccwebb
Aug 11, 2015 06:47 PM
