WARNING InDiCaToRs!!!
Old Feb 13, 2008 | 08:08 PM
88ttops's Avatar
88ttops
Default WARNING InDiCaToRs!!!
My low fuel, washer fluid, and check oil lights all come on and flicker and turn off and onperiodically.. Sometimes they stay on for awhile and other times they will flicker until the car warms up... What could this be?? what should i check...
Old Feb 13, 2008 | 08:15 PM
302f150's Avatar
302f150
Default RE: WARNING InDiCaToRs!!!
find a handy dandy wiring diagram, and see what they share. either ground or power, and its prolly shorting to something. u ever had the dash out?
Old Feb 13, 2008 | 08:22 PM
notchbackmatt87's Avatar
notchbackmatt87
loose connection.
Old Feb 13, 2008 | 09:25 PM
AdderMk2's Avatar
AdderMk2
Banned
ignition switch!
Old Feb 13, 2008 | 11:07 PM
89gt347's Avatar
89gt347
put a sticker over them and they will go away!!
Check a wiring diagram and trace the short or loose connection.
Old Feb 14, 2008 | 12:45 AM
Tberg725's Avatar
Tberg725
Just pull the dash out and pull the light blubs out, problem solved works everytime.
Old Feb 14, 2008 | 10:50 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
ORIGINAL: Tberg725
oh yeah that'll solve the problem what do you think warning indiacators are for huh??? to warn you in the event of a problem.........anyway check all connections and have the alt tested also..if all that checks out could be and ignition switch as mentioned above
Old Feb 14, 2008 | 12:46 PM
Tberg725's Avatar
Tberg725
Haha I was kidding.
Old Feb 14, 2008 | 05:43 PM
88ttops's Avatar
88ttops
Thanks everyone but i think it is the ignition switch (i have had a problem with the plastic separating before but had not had problems since)... I had already checked all connections and the wiring harness before i posted about it... That parts pretty common sense, but i guess there are a lot of people lacking in that area lol... Thanks again...
Old Feb 16, 2008 | 03:56 PM
88ttops's Avatar
88ttops
OK!!!!!!! I changed the switch, which was coming apart again, and it did not solve the problem... I checked through the engine bay harness and everything looks good.. I am thinking maybe something to do with the instrumentation or dash??? not sure..
Jb145700
Aug 21, 2022 06:37 AM
jwog666
Dec 27, 2021 08:09 PM
Explosive
Oct 2, 2015 07:45 AM
ChampInSD
Oct 2, 2015 04:55 AM
TfcCDR
Sep 14, 2015 12:08 PM
