FenderWall Selenoid Question
We'll i have a question the wire on the Fenderwall Selinoid not the Pos+ or Neg- Post but the top middle post there is one wire going there that is red .! ? What does that control the Ingition Switch ?
And what kind of wire to i buy to replace it , And what is the proper way to replace it with "BUTT Connectors"?
RE: FenderWall Selenoid Question
Go to your local parts store and buy a crimper and connector. I wouldn't half *** my connections there. One side should be hot all the time and the other not. Also that is your ingnition power wire, and I would suggest the same gage wire if you are planning on replacing the wire. Correct me if I'm wrong. Patience my friend. Take your time do it once!
We'll i plan on doing it right. That's why im asking for information, Now first of all i dont know what kind of connecters to Buy!...
I do have a CRIMPER And I have Some "Butt Connectors" , Should i used the but connecters.
When you say one side should be hot all the time and one should i really dont understand at all what your talking about . Im not good with Electrical lol. But i would appreciate if you help me ..
And the gauge wire'! How do i buy the same gauge when i dont know what gauge the wire is .
There should be three bolts coming off the top of your selenoid. The two main ones are (power in from the battery & and power out to the starter. If you buy or have a "poke" meter. This looks like a screw driver with a wire coming out of it that you ground to whatever metal is nearby whatever you are testing. You need to make suer your getting power first. The wire coming from the battery should be "hot" or have power running through it at all times. When the selenoid is engaged it closes the circut and gives power to the other wire that is hooked to your starter. If I were you and didn't know what kind of wire or connectors to buy. I would take off my old wire and connector and go to local PS. Ask the guy if you have to, wires and connectors are standard stuff and they should be able to help you no problem. Try doing a little research to. "Google = Auto wire gage size". Good Luck man
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
