smog pump ughhh
Old Feb 22, 2008 | 03:13 PM
89mustangfive0's Avatar
89mustangfive0
Default smog pump ughhh
my smog pumo crapped out so i put a new one on and when i go to put the belt on it wouldnt go on...so i loosend the smog pump and moved it over and even then it was a struggle to get the belt on...what did i do wrong( besdies putting the smog pump back on the car) ?
Old Feb 22, 2008 | 03:16 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: smog pump ughhh
are you releasing the tension on the tensioner via a 18mm socket and breaker bar??
Old Feb 22, 2008 | 03:19 PM
89mustangfive0
yes i am lol before i took the old one off the belt would gon and off easy.after i loosend the new one and moved ittoward the driver side a little the belt went on but still hard to do..
Old Feb 22, 2008 | 09:49 PM
89mustangfive0
ahh can anyone help me?????
Old Feb 22, 2008 | 11:10 PM
-SHIFTY-'s Avatar
-SHIFTY-
delete, delete, did I say that
Old Feb 22, 2008 | 11:12 PM
89mustangfive0
hah thats why i said what did i do wrong ( besides putting it back on) gotta cause my dads making me frigin guy. thinks its his car to
Old Feb 22, 2008 | 11:13 PM
mjr46's Avatar
mjr46
make sure the pump is the same as the old one and all mounting points are the same location and distance
Old Feb 22, 2008 | 11:19 PM
89mustangfive0
yea it was the same pump exactly only thing is i dont have the bottom mount brakcet so it was helo on by the one bolt below the altenator...i had loosend the altenator also...im thinking its possible i have either the pump or altenator too far over one way making the belt hard to get on... does that sound possible??
Old Feb 22, 2008 | 11:22 PM
-SHIFTY-'s Avatar
-SHIFTY-
Yep make sure they are the same, could be different size pullie???? Thats so minor though shouldn't be causing you that much trouble. Its a simple set up, take a step back. Make sure its lined up correct, belt is run properly, and tensioner is adjusted properly.
Your brackets and blots should line right up. There should be NO play there
Old Feb 22, 2008 | 11:24 PM
89mustangfive0
the pump didnt come with a pulley so i kept mine it was the same thing...i think when i put the altenator back on and pump( i didnt pay attention i rushed) i didnt put them in the proper place and thats why the belt wouldnt go on..i kinda threw it on there cause i had to get the car to the shop to get painted.
jwog666
Dec 27, 2021 08:09 PM
Bokeo
Oct 10, 2015 08:28 PM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
Teddi
Sep 29, 2015 12:24 PM
mrappe
Sep 26, 2015 10:16 AM
