clutch goes pop?
clutch goes pop?
When I push the clutch in the pedal goes in part ways and then when it's almost all the way down "POP!" and the clutch pedal becomes loose. I can re-engage it by pulling up on the clutch pedal. then the same thing happens when I push the pedal down again. what could be the problem? '87 5.0.
I've removed the clutch quadrant and the clutch cable from the firewall and the clutch cable has play. I can move it back and forth with little effort. Hope this helps.
RE: clutch goes pop?
but even after taking it out there is play in the clutch cable. is this normal? I thought the cable was supposed to be tight. I can move the steel braided cable back and forth easily. I haven't put the new aluminum quadrant back in 'cuz I don't have an adjustable cable or the firewall adjuster.
1) can I putthe quadrantback in w/o any adjustment (cable or firewall)?
2) isn't the clutch cable supposed to be tight (with no play)? - I didn't disconnect it from the clutch or bellhousing.
junior04
09-28-2015 10:53 AM
