buildin 306? questions
Old Feb 27, 2008 | 01:42 PM
66blownmustang66's Avatar
66blownmustang66
Default buildin 306? questions
how much would it be (about) to get a block machined to a 306... ??
Old Feb 27, 2008 | 01:53 PM
jtmustang's Avatar
jtmustang
Default RE: buildin 306? questions
depends on how much work the block needs to make it strait and true
the 306 i just got done building the block neede a lot of work the normal bore and hone cam bearings,tanked,magnfluxed,was like 350 i think. but i also had to main line bore it and they had to deck it to get it nice a and flat that was another300 bucks .then i had the stock rods installed arp bolts,resized the rods and shot peened,another 150,also hang my new pistons and had them gap the rings another125, as you see it gets expensive i had a total of 1400 in machine work as i had my valve springs swapped out and i forgot with new pistons,balancer,billet flywheel u will have to balance as i did another 225.
Old Feb 27, 2008 | 02:28 PM
disturbed471985's Avatar
disturbed471985
cheaper to just buy a new shortblock.
Old Feb 27, 2008 | 05:18 PM
floodzilla's Avatar
floodzilla
It might be better to boost. s/c or turbo, definatly end up being cheaper.
Old Feb 27, 2008 | 06:24 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
when it's all said and done right you could spend any where from 250.00 to 500.00....depending on what you need done..machine shop will tell you after careful checks and inspection of it
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
