KB pistons
Old 02-27-2008, 03:48 PM
66blownmustang66
66blownmustang66's Avatar
Default KB pistons
are keith black pistons blower applicatable???
66blownmustang66 is offline
Old 02-27-2008, 05:08 PM
P.S.I.cho
P.S.I.cho's Avatar
Default RE: KB pistons
that will depends on more then just the pistons, you need to take your cylinder heads into consideration, and calculate your compression ratio, and then it depends on which KB pistons u have, if your running the hypereutechtics then no i would not run a blower setup with those pistons.
P.S.I.cho is offline
Old 02-27-2008, 06:11 PM
my77stang
my77stang's Avatar
you can run some boost with hyper's but i wouldnt go crazy, keeping your compression in check is key so you need to know which pistons you currently have
my77stang is offline
Old 02-27-2008, 06:19 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if you want excessive amounts of boost availible to you then forged kb's would bee your best bet
mjr46 is offline
Old 02-28-2008, 08:36 PM
P.S.I.cho
P.S.I.cho's Avatar
ORIGINAL: my77stang
yes in perfect world you could, but since we all here are human, mistakes can happen and with the loads a boosted application put onto these pistons, with one mishap in a tune even a minor malfunction can cause a crack in the hypers, a more serious detonation problem can actually shatter a hyper piston, save your self the hassle and calm your nerves and stray away from hypers in a boosted/nitrous application
Old 02-28-2008, 08:50 PM
MadMan@TheWheel
MadMan@TheWheel's Avatar
I good general rule of thumb with blower/turbo applications.
Forged pistons.
MadMan@TheWheel is offline
uberstang1
12-07-2017 07:10 AM
poke68
12-15-2015 06:25 PM
uberstang1
09-20-2015 06:42 PM
degner122
09-16-2015 07:09 AM
EASTIDEE123
09-14-2015 03:52 PM
Quick Reply: KB pistons
