Can i use my stock CC plates with qa1 coil over setup???
caster is non adjustable with factory set up... they are only for camber and from the factory is locked in place via a rivit..... why would you want to half ace it?? caster camber plates are at most 150.00 for a decent set..and will give you the full range needed to set specs on alignment properly... trust me!! been there done that.. I have the complete D&D set up on mine with m/m castr camber plates
