Speedo recalibration>???
Old 03-06-2008, 01:33 AM
tom29
tom29's Avatar
Default Speedo recalibration>???
hey guys i got my other rear end put in last week with the 3.73's. i did have 2.73's in and i was just wondering what speedo gear i would switch out if i can just change the gear and not the whole cable. car has AOD with 3.73 rear. im pretty sure its just a color coded gear..
thanks guys any info appreciated
tom29 is offline
Old 03-06-2008, 01:52 AM
nyfreakinrican7
nyfreakinrican7's Avatar
Default RE: Speedo recalibration>???
21 tooth gear $10.95 part #lrs-17271G from Late Model Restoration
nyfreakinrican7 is offline
Old 03-06-2008, 11:19 AM
tom29
tom29's Avatar
ok thanks ill probably just get it from my buddies tranny shop.
tom29 is offline
Old 03-06-2008, 03:46 PM
stang8689
stang8689's Avatar
Real easy to install
stang8689 is offline
Old 03-06-2008, 05:08 PM
bighungrymatt
bighungrymatt's Avatar
red 21 tooth, and yes its one of the easiest things to install
bighungrymatt is offline
Old 03-06-2008, 07:15 PM
nitrous_bob
nitrous_bob's Avatar
all these answers are wrong so far.
first off, aod and t5 gears are different color coded as they have a different pitch
the purple 21t gear for the aod is good for 3.27's, not 3.73's
the aod cannot swap out the drive gear, it is fixed 8t machined on the shaft
so basically w/ a ford driven gear you can do the 21t purple and be about 12-15% off, or get the white 23t (it's a jeep part and wrong pitch for any ford trans)which will wear out eventually....5k-10k miles usually on aod cars and you will be 6-8% off still and have to replace it whenever it wears out
you have no fix, other than get a calibration box, i'm quite sure they are big $$ though
if you tear your trans apart and can find a 7t output shaft , then a 21t would make it good
nitrous_bob is offline
Old 03-06-2008, 08:18 PM
bighungrymatt
good eye, I didnt even catch it was an aod [&:]
67LimeCoupe
11-25-2015 08:55 PM
Mr. D
Tuner Central
08-27-2015 05:01 AM
Mr. D
Wheels & Tires
15
08-22-2015 02:58 PM
Gregz
08-11-2015 03:42 AM
qwikhuh
12-01-2003 04:26 PM
Quick Reply: Speedo recalibration>???
