burnt tranny fluid?
burnt tranny fluid?
i was checking my tranny fluid and some of it looked burnt i havent been driving it lately but it was slipping i got new fluid+filter to change when i get a chance you think my tranny is toast?
RE: burnt tranny fluid?
Could be...when you drain your dark fluid, look for flakes at the bottom of the pan or in the drained fluid. If you find some, I'd start getting worried. A little bit of 'sediment' is normal, flakes are not, they are from your bands.
I would still go through the radiator and then route the trans lines to the external cooler. I think your losing some cooling potetial if you don't do it that way. You are making the only outlet for heat the external cooler which isn't made to be the primary heat sink. The cool side of the radiator, which is where the heat exchanger for the trans is located, runs at about 120 to 160 degrees. The trans fluid routinely goes well over 200 degrees so there is a lot of cooling that can take place. In the case of the engine overheating it depends. If the thermostat sticks then the cool side of the radiator will still be relatively cool. You can't drive far overheating so the trans shouldn't be affected. You definitely will get better cooling to the trans if you keep the stock in radiator connected and then add an external as well.
treesloth
09-28-2015 07:03 AM
09-25-2015 06:42 PM
