Gasket set question
Gasket set question
Ok, i'm building an 87, CARBED engine to put into a fox. I was wondering if a carbed gasket set for an 82-85 302 will work. its the same engine right? just not carbed? he also has the 87-93 gasket set, but it is for a fi engine. so will this work?
thanks!
thanks!
RE: Gasket set question
I've used the except high output ones before...you should be fine just make sure all the intake ports and water jackets line up on intake gaskets and the head gaskets have all the correct holes in them.....a 9333 pt1 is the head gasket number I believe??
