turbo on carbed 302? any knowledge of this?
alright i was talking to a a few days ago and he was talking about doing a blowback turbo to a carbed 302(well a 306) i wanted to learn more about this as ive never heard of it. does anyone know anything about this?
RE: turbo on carbed 302? any knowledge of this?
You use a carb with sealed throttle shafts and reenforced floats, and enclose the carb, or run a bonnet on it. It's called blowthrough. You don't see it a whole lot, but it works very well.
Dude one of my buddys has a 302 with Trick Flow Twisted Wedge heads, and a built bottom end, with a homemade turbo set up. I will say I was impressed, his car flys, he runs drag radials(Nitto) and runs 11.50's, not bad plus hes still messing with AF Ratio's and what not.
hope this helps, if your mechiancally inclined theres a how-to blowthru fabrication setup etc...if not steve morris can build you a blow through carb setup if you give him a call, hes a little pricey but its quality work
http://www.hangar18fabrication.com/blowthru.html
www.stevemorrisracingengines.com/
my buddy has a blowthrough setup on his 351, we got the demon blowthrough 750cfm carband a cam and it works great. im thinkin gof doing this on my next motor, its sooooo much easier. we did the whole project in a weekend in my driveway.
o cool that all helps alot. i guess i knew all along what this setup was i just didnt realize it. im thinking about doing this setup but how much power can you push safely? it would be alot easier for me to slap on some nitrous though
Nitrous is easier, but expensive in the long run. blowthrough setups are the easiest of turbo setups, no messin with computers or expensive efi parts. im currently runnin about 450 on the street, 600 for playin around. (i know its a time bomb but hey, if it blows, it justs give me a chance for a bigger better motor)
ORIGINAL: Rajun_Cajun
Talk to (CPRStreetmachines) on here. Both Richard and Dustin have blow through setups that they built and tuned themselves.
Richards car...
Richards car...
bradleyb
11-27-2015 07:50 PM
jaiidutch
09-14-2015 10:29 AM
