4 to 5 lug conversion - front rotor question
Old Mar 13, 2008 | 10:27 AM
5.0kidsdad's Avatar
5.0kidsdad
Default 4 to 5 lug conversion - front rotor question
Will rotors from a '92 Lincoln Mark VIII LS fit a '92 Mustang which has disk brakes and 4 lugs? I was told thats all that I need to convert the front brakes to 5 lugs. I was told the '92 Mustang already came with "big brakes" and the rotor was the only thing I needed to change? Was told the caliper, caliper mounting bracket and spindle where fine and would fit the above referenced rotor. Can anybody confirm this? Thanks for your help!
Old Mar 13, 2008 | 11:00 AM
r.barn's Avatar
r.barn
Default RE: 4 to 5 lug conversion - front rotor question
It's better to use the 1994-95 Mustang GT front spindles and brakes
They are on ebay all the time. Then just run stock SN95 Mustang front rotors.
http://cgi.ebay.com/ebaymotors/SN95-...spagenameZWDVW
Very good write up on to do the swap correctly with "junk-yard" parts
http://www.stangnet.com/tech/lug.html
Old Mar 13, 2008 | 05:54 PM
5.0kidsdad's Avatar
5.0kidsdad
ttt
Old Mar 13, 2008 | 06:00 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Yes, what wheels are you looking to run
Old Mar 14, 2008 | 11:02 AM
5.0kidsdad's Avatar
5.0kidsdad
Have not picked any out yet PRO. Is there something I need to be aware of in regards to different wheels not fitting? Thanks
Old Mar 14, 2008 | 12:08 PM
primetime5.0's Avatar
primetime5.0
yeah when you just swap rotors 90% of 5 lug wheels wont work
Old Mar 14, 2008 | 02:45 PM
ram2sak's Avatar
ram2sak
pick your wheels first
take a look at sn95brakes.com it will explain alot
Old Mar 14, 2008 | 04:05 PM
uedlose's Avatar
uedlose
yes the rotors will work I have them on my car but I ran into the center of some of the wheels being to small for the rotor but my Monocoque racing wheels fit no problems at all. But I have seen others say they had no problems at all with wheels. it is very simple and cheap bolt on just take your old ones off put the new ones on nothing to change other then the rotors and wheels.
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
