Speedo Gear
Old 10-13-2003, 02:07 AM
kornfan_88
kornfan_88's Avatar
Default Speedo Gear
I just had my stock T-5 go out on me and I put in a world class T-5 (didn't have the money for a temec....actually didn't have the money for the t-5 but...) Is the world class geard different from the stock t5? Does it need a different speedo gear? Cuz now when I'm going down the highway it says i'm doing 85 at like 1800 rpms and i know i'm not cuz big trucks are passing me. Any help is appreciated.
kornfan_88 is offline
Old 10-13-2003, 03:09 PM
horatio102
horatio102's Avatar
Default Speedo Gear
Go out on the freeway and do this:
reset your trip meter at a mile marker (any mile marker)
now drive exactly ten miles (find the 10th mile marker)
Look at your trip meter - how many miles does it read?
Then pull out your speed sensor and count the teeth on your existing speedo gear.
Then find a shop that carries speedo gears and that makes gear reduction/adduction boxes. Tell them what you've found (#teeth, # miles). You may be able to just swap the speedo gear, but you may have to have your speedo cable cut and a converter box put in (thats what I did).
I don't know how you find shops that do this, I just stumbled across one (it's a local company (not chain) that carries auto parts, tools, and paint stuff but has a machine shop out back). If you can't find one near you I can get you in touch with this one.
horatio102 is offline
Old 10-13-2003, 11:52 PM
jadakissnas33
jadakissnas33's Avatar
Default Speedo Gear
u proble have a newer speedo gear in there from when mustangs had a 140 speedo u proble have 85 on urs try switching the speedo gear to a pre 90 1
jadakissnas33 is offline
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: Speedo Gear
