trick flow kit
is this kit any good? it comes wit the twisted wedge heads, camshaft. roller rockers, track heat lower and upper intake, head bolts, timing chain and gears,gaskets,valve covers and more
http://store.summitracing.com/defaul...=egnsearch.asp
Well as far as packages goes, no, if I were going to use one that would be it. Its good if your not sure what kinda cam/heads you want etc. That cam is matched to those heads, which is great. Its also a pretty good value.
That sounds like a great street machine...and probably good ET's. That kit is a good kit!. My friend bought it and was pleased. Also, Trickflow intakes are designed to make their power in the higher rpms like 3000rpms+. So if low-end power is what u want, pick up some big gears. Or u can sell the trickflow intake and get the GT40 intake. It supplies great topend power and retains the stockers lowend power too. I have the Trickflow becuz i like being in the higher rpms.....Just stuff to think about. Good luck!
i'd like to upgrade my intake kit. i'm not looking for something to give lots of power at 6000 rpm's or anything. i'm usually nice to my car. but anywhere from idle to 5000 would be awesome. anybody got a kit for me to look for like this?
I dont know if someone sells a kit with this stuff but for ur application id look at: Ecam, gt40x alum heads, and gt40 intake....Also look at the holley systemax kit. They got that at summitracing.com i believe.
blk89 & bushdude you will like this kit i think. look at those 2.02 valves, and the 1 piece push rods, and the true roller timing gear set, & etc,. take your time and select the intake you need & some of the other parts also. summit will work with you . this is a good kit for the money. i like mine i have for 1 of my mustangs, and i am trying to get another tfs-tw kit for my carbed mustang. you can get the kit to match your rpm range. good luck.
jwog666
Dec 27, 2021 08:09 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
