whats the difference...heres the specs.
Heres a comparison between the E and the B cams. I dont see why the b is better...which is all around better,ie. good lopey idle, good powerband, daily driver compadibility.whats better for my setup, Im staying N/a with a stock 302 Im just going to do heads and intake, no stroker or anything. which cam would be better.comparison between cams
RE: whats the difference...heres the specs.
both are good for street. i do belive the ecam has more low end power and the bcam has a little more top end power. I have the Ecam and it does great for street/strip use. If I was in your situatuion I would look into the trick flow stage 1 cam (.499/.510).
Cavedawg
09-17-2015 09:51 AM
