who all has the edelbrock performer rpm 2 intake?
#22
RE: who all has the edelbrock performer rpm 2 intake?
Ok say I didn't plug off both of those 3/8 inch holes in the back of the lower intake and I put the hose fitting off of my original lower intake there (back side left)...what goes on that fitting?
#26
BTW to any one reading this, this is the last time I'm ever going to buy from Edelcrap. The instructions are terrible (my shop teacher who was a certified mechanic couldn't even understand them), some threads are too tight and vice-versa (2 out of the 4 stock bolts that held on the fuel rail were too big for the threads), when I went to retap (very lightly) one of them so the bolts would fit, it poked through to one of the runners extremely easy, and after waiting on hold at least ten minutes (no joke) every time i call, the customer service people don't even know what they're talking about. You would think they'd be able to tell you where some of the fittings go but depending on who you talk to, they'll either tell you something different from the last person u talked to, or treat you like an idiot.[sm=rant.gif]
#28
ORIGINAL: jrt1990
Hey man I can't thank you enough. Wish I could repay you somehow. I just had a couple more questions...
ORIGINAL: FivePointOhh
the red dot on my intake was blocked off, i dont need it.
the blue dot is vac line that goes right to your main vac tree.
for that T fitting i suggested capping off one side due to it only needing to run from your lower intake to your upper intake for the pcv system. the other side is not needed.
zanemoseley
09-06-2015 12:58 PM
