ignition
trick flow stage 1 cam..twisted wedge head...24 lbs injector...190lph fuel pump..gt-40 intake...70mm TB..75mm MAF...pulley...smog pump eliminator...3/8' intake spacer.. king cobra clutch...bbk shortie header...h pipe... magnaflow cat back.. trick flow timing chain.. tick flow chromoly 6.7' puch rod...comp cam roller rocker..fuel pressure regulator...k&n..accel ignition with ford racing 9mm wire ...stock block and that sit
with this setup .... do you think i need msd 6al and what will be the pefect gap for my spark plug now
thanks
thanks
bradleyb
Nov 27, 2015 07:50 PM
jessicarabbit
Sep 25, 2015 12:41 PM
