Water in oil and driving :(
k i got my car running and took it to my school and when i got there i opened the valve cover filler and the oil was a white foamy colour so i guess water got in the oil but i drove 11KM and i drove about 70-80km a hour the whole way, and i was staying like under 2000 rpm, so im just wondering if i screwed anything up because i gotta go drain the oil in the morning "(
RE: Water in oil and driving :(
Im no epxert, but it sounds like your pretty screwed. Lots of white smoke coming out the exhaust? Blown head gasket maybe. Unless if it was sitting for a long time and maybe moisture got in there. I'm sure someone will have a better idea than me.
unless the timing cover was off .......doing a water pump won't get coolant in the oil and if the timing cover was off you'd have to get a crap load in there to get a milky mess and after such a repair before start up you should of changed oil if coolant was dripping into the pan as a result of the cover being off
i did change my oil and filter and after it was still leaking water so i took the timing cover, and water pump off and put new seals in and water i think dripped down wouldnt that cause it to get milky? and yes i know im a F******** idiot and shouldnt of been so god damn impatient but im hoping i dont ahve a blown HG
ORIGINAL: jerod187
