speedometer reading is wrong?
Old Apr 8, 2008 | 10:04 AM
jasonpnoy916's Avatar
jasonpnoy916
Default speedometer reading is wrong?
my speedometer says 60 mph but really i'm only going 40 mph... i even drove side by side with my bro to really find out... what do you think is the problem?
Old Apr 8, 2008 | 10:14 AM
TI302's Avatar
TI302
Default RE: speedometer reading is wrong?
rear gears, or overall tire diameter. you can get speedometer gears from 50resto to correct
Old Apr 8, 2008 | 10:39 AM
jasonpnoy916
thanks bro
Old Apr 8, 2008 | 02:53 PM
TRexGAWD's Avatar
TRexGAWD
Did you chang your rear gears or put different smaller sized tires on??? If you did then make sure you replace the gear with one that has the correction factor suited for whatever you are running.
Old Apr 8, 2008 | 04:49 PM
nitrous_bob's Avatar
nitrous_bob
is it 5-speed or aod ?
also what year......every store will tell you get a 23t gear, but thats not always the case....aod cars cannot be corrected past 3.55 gears, and depending the year, a 5-speed cannot be corrected past 3.73 w/ out using the non ford 23t white gear that will chew up in there.
there are 2 gears, drive and driven
if it's a 6t, then your ok 7t cannot correct for 4.10's..... 8t like in all aod's cannot be corrected past 32.7 w/ ford gear, and 3.55 w/ the white one
mtgldr
Feb 3, 2024 09:00 PM
articman
Jun 21, 2018 11:45 PM
MusicCity615
Sep 12, 2015 07:05 AM
algregory
Sep 11, 2015 11:44 AM
zanemoseley
Sep 6, 2015 12:58 PM
