E303
Old Apr 8, 2008 | 07:13 PM
86 Mustang GT's Avatar
86 Mustang GT
Default E303
I was told that i could run an E303 cam with twisted wedge heads on my stock 86 without notching the pistons, is this true?
[/align]
Old Apr 8, 2008 | 08:34 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: E303
you should be fine just check ptv when doing it
Old Apr 8, 2008 | 08:52 PM
OneFine89Mustang's Avatar
OneFine89Mustang
Default RE: E303
it should work
Old Apr 8, 2008 | 08:55 PM
TRexGAWD's Avatar
TRexGAWD
Default RE: E303
Should work but you won't get the full potential of the TW's with an E cam... Do you plan on changing it later on?
Old Apr 8, 2008 | 11:03 PM
lxman1's Avatar
lxman1
Default RE: E303
I'd be more worried about the pistons not having valve reliefs so definately check clearence with any cam that you use. even stock.
Old Apr 9, 2008 | 09:24 AM
86 Mustang GT
Default RE: E303
I want a real lopey cam and i was told the E303 would be just that, but what cam would you recomend to use with the twisted wedge.
Old Apr 9, 2008 | 09:46 AM
mjr46's Avatar
mjr46
Default RE: E303
ORIGINAL: 86 Mustang GT
e-303 is not that lopey..I'd be more concerned with performance than sound....but if noise is what you want in your case I'd strongly reccommend having a custom cam designed that way you could get the best of both worlds
Old Apr 9, 2008 | 09:58 AM
itsslow's Avatar
itsslow
Default RE: E303
if your car is still speed density i would not recomend you that cam,you'll have your idle all over the place and run like ****.i got this cam from a friend for free but now i regret ever putting it in.
86 Mustang GT
Default RE: E303
Dont get me wrong i would much racher have performance than sound... Where could i geta custom cam made and about how much would it set me back
Old Apr 9, 2008 | 10:05 AM
Joel5.0's Avatar
Joel5.0
Default RE: E303
Camshaft Innovations LMK
