3.73 install
RE: 3.73 install
So looking at the labor it seems like it isnt very complicated? I want to get 3.73s and always do mechanical work myself. Question is how long of a job is it? 4-5 hours?
I charge people more than that to install complete audio systems in their car....that is just about a 6-8 hour job.
So I am assuming 4-5 hours for the gears?
RE: 3.73 install
ORIGINAL: Pure5.0
it took me about 11 hours, it was my first time, and I rebuilt my carrier, (put new clutch packs in) I had access to air tools and a press, and a special bearing clamp thing, that holds the bearing while you press the carrier/pinion gear off.
I would reccomend if you do it yourself, to at least get a dial indicator with magnetic base, and measure everything, then try to get it the same with the new gears, and don't forget to break them in properly.
09-10-2015 08:39 PM
