how much E.T are pulleys worth
RE: how much E.T are pulleys worth
ORIGINAL: roundman
Yes, but if he don't increase the size of the water pump and alternator pulleys, then he ain't really going to be "underdriving" them, will he???? LOL
ORIGINAL: vfast
1-2 tenths...that pulley does the most not the alt or the W/P pulleys..good choice
Changing the crank to 5.5 inches and keeping the alt. the same results in a ratio of 1.8:1. I don't the ratio of the water pump because I didn't figure that one out.
If I was also to increase to alt. pulley, then that would have dropped my ratio to 1.3:1, which I thought would be too low a ratio and have charging problems.
That's why a lot of guys complain when they buy these pulleys that their alternator won't chrge enough and they can't keep the engine cool enough at idle......they changed the ratios to radically.
It's all simple math...divide the driven pulley(alt.) size into the driving pulley size(crank) and you get your ratio.
Try it...plug in different numbers and you will that you only actually need to change the crank pulley.....
Class is dismissed now...for homework, review chapter 1 on simple pulley mechanics and ratios....LOL
ORIGINAL: import slayer
Yes, I will be still be underdriving them. If my crank pulley was 8 inches and my alt. was 3inches then my ratio was 2.6:1
ORIGINAL: roundman
ORIGINAL: vfast
[sm=hail.gif][sm=hail.gif][sm=hail.gif]
ORIGINAL: Predator
I take it this is a math class, because if it was english, you'd get an F
I'd be suprised if anyone else, besides you and I, know what a prepositional phrase is or can actually list all 41 prepositions...LOL
Who cares though? As long as I can read people's sentences, and make sense of it, I'm ok.
Actually, I am good at English. I don't always use commas to seperate my prepositional phrases.
ORIGINAL: Predator
E=McHammer?
ORIGINAL: 87 hatch
YOU BUNCH OF BABIES. QUITE CRYING OVER WHOS SMARTER. THIS IS A SITE ABOUT HELPING PEOPLE OUT. RIGHT???
Seems like you need some grammer help too. You mis-spelled quit and should have put an apostrophe between the "o" and "s" in who's.
Now.....you can shut up.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
treesloth
09-28-2015 07:03 AM
