intake manifold problems help please
i have a bone stock 86 mustang gt, i put a trick flow intake manifold the hole unit and the problem is that it dont want to stay started at idle. the only thing i think it is that i am not getting a enough fuel or that my throttle body is to small. not for sure what the problem is please give info thanks for reading
RE: intake manifold problems help please
not that i herd i mean it starts fine and it just dose not hold throttle it just dies when your not on the gas. i mean i am running the stock 62 mm throttle body i think thats the problem but i dont want to buy a new one and thats not it i want to make sure
Just reading on Trick Flows site is says 75mm so that may be it but not certain. If it stays running giving it gas, does it have a rich smell from the exhaust?
ORIGINAL: mustang freak
i'd say you need set the idle,tpsand reset your computer. thats assuming you truly don't have any vac leaks, because if you do...thats the problem
cardsrus1
19
09-15-2015 08:37 AM
Calizic
08-28-2015 01:46 PM
