rear is toast
RE: rear is toast
the 4 eyed e brakes are easy as pie to adjust just a bolt on it to tighten, while the aero nose stangs need to be wound up causing it to be a PITA to do. another reason that the 4 eye rocks!!!
RE: rear is toast
ORIGINAL: 86whitepony
RE: rear is toast
First off, this is the 108970 time Kyle has said his rear is toast
Second, the Ebrake is a funny since his first 1/4 run he left his on.... haha
Third, my Fox does not have a e brake since I changed to turbocoupe disc : ( but yay for high compression!
Anyways Kyle, those gears were just dying to get into your car and since you know how to throw them in, your saving lots of money!
RE: rear is toast
yes ill admit it the first 1/4 mile run i ever did my ebrake was parcially on. and alex i have only told you 38430928 times my rear is toast i was not just saying how bad it really was. [8D]and yes i know i can set up gears myself i just dont have the 350 for the gears clutch pack and bearing/shim kit
RE: rear is toast
Man that sucks about the rear end, at least yours partially worked. My rear end literally exploded, sounded like a gun went off. Both gears had 0 teeth left. It was quite sad. btw my ebrake still works
RE: rear is toast
yeah and since i dont drive on the highways i really dont have to worry about blowing it up cause im never going that fast. i just gotta get the 8.8 i have done so i can get home next month.
RE: rear is toast
yeah itsa 7.5 and im not gunna rerout the brake line just yet its gunna stay where it is because i dont have the time to do that. i would have to redo the whole hard line and thats not happening anytime soon.
