cam install help
RE: cam install help
magnet will be useless....why???? just how do you think you'll get the lifter out of the drain plug hole??? a lifter is bigger than the hole....drop the pan = no way around it
I ment a magnet out thru the top, obviously it probably wont work.
I'm all for doing projects on your own but you should do enough research before hand to know how to do the job right.
ORIGINAL: OnyxCobra
Luke9222
10-22-2015 11:55 PM
