Electric fan wiring
Electric fan wiring
I have a lincoln towncar electric fan and i wanted to know how to wire it up. This is the fan that everyone is saying to get from the juckyard isnt it? Here is a picture to make sure i have the right fan.
[IMG]local://upfiles/12890/4BDC7C1367D34D4CB260703A0D02491E.jpg[/IMG]
RE: Electric fan wiring
call up summit and order a flex a lite fan controller for 80 bucks. its the best thing to use. i got one on my truck, stang and a few other buddies rides. its worth the money. all the wiring and connectors are there.
ORIGINAL: 88PatrolCar
You can also run it through an ignition wire so when you turn your car on the fan turns on and stays on till you turn it off.
Make sure you hook it through a relay and an inline fuse.If your car doesn't have the low coolant light you can use a wire from the plug.It is next to the overflow bottle on the radiator support.
ORIGINAL: stanglx2002
thats what i want to do which wire should i use?
If you look at the ignition coil, the harness that plugs into it, I think one of the middle wires stays on when the key is in the II position. Use a multimeter to find out which one this is. Tap it to that wire. Don't worry about the fan robbing power, the switch wire is only to two little magnets inside the relay for the fan, it doesn't use much power at all.
Get a standard relay if that fan doesn't already have it. I see a bunch of wires in that pic, which might be to a relay, not sure, if not, it's about $15.
So it's a pretty cheap process.
I got my fan installed for about $30 after everything that I needed and it works like a charm, and yes, that fan is very similar to the Volvo fan we recommended earlier in another thread.
jwog666
12-27-2021 08:09 PM
09-25-2015 09:06 AM
