quick help please!!
Old May 6, 2008 | 12:42 PM
GaryBisiniere's Avatar
GaryBisiniere
Default quick help please!!
i have an aftermarket clutch cable and quadrant that worked on my 89 5.0 and im installing it on my 90 and it dosent seem to reace the clutch fork......?
helppp
Old May 6, 2008 | 01:58 PM
WhiteWindsor's Avatar
WhiteWindsor
Default RE: quick help please!!
Are you prying the fork with a bar?
Old May 6, 2008 | 03:56 PM
nitrous_bob's Avatar
nitrous_bob
does the quadrant have 1 or 3 notches to hook ?
and are you removing the locking nuts and just putting the threaded rod through ? you showln't have any issues, they are all the same '79-'93
Old May 6, 2008 | 10:19 PM
GaryBisiniere
i was just removing the pins and putting the metal piece on the rod. do i have to remove the nuetral safety switches? because that looks like it would let the cable down more... and no im not prying it with a bar..... i never did before. i just pulled on it and that was enough to get the nut through...
Old May 6, 2008 | 10:54 PM
GaryBisiniere
i also was thinking maybe the throuout bearing isnt seated right. any1 have a side pic with tranny up?
Old May 7, 2008 | 06:38 AM
GaryBisiniere
any1? its really blowing my mind that its not working on my 90 so fustrating.
Old May 7, 2008 | 06:40 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
The quadrant is above the gas pedal. You shouldn't be doing anything on/over the clutch pedal itself. If that's what you're doing.
Old May 7, 2008 | 07:31 AM
GaryBisiniere
ya i put the metal piece to the rod with 2 pins.. put the clutch cable on that piece in the car... quadrant is all the way screwed in leaving the most slack on cable and its like a half inch short of the clutch fork. this whole setup worked on my 89 last year.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
svfetter
Oct 5, 2015 11:39 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 25, 2015 06:30 PM
