Weight Reduction
Old 05-10-2008, 07:41 AM
Tha Boss
Tha Boss's Avatar
Default Weight Reduction
I have an 88 gt and I've put my motor together and hoping to crank it within the next couple of days. I was trying to get sum weight off the car and I was wondering about some odds and ends that might take off some pounds. My goal is to try and lose 200 pounds. Dont know how much the stock gt weighs but I have taken out the gas tank(have a fuel cell), the back seats r gone, and I was wondering where else can I lose some weight. Thanks any and everybody
Tha Boss is offline
Old 05-10-2008, 08:36 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Weight Reduction
you coud remove the bumper covers and remove the metal reinforcement bumper behind it....but I'd only do that if it's a mainly strip car
mjr46 is offline
Old 05-10-2008, 08:37 AM
mjr46
mjr46's Avatar
remove sway bars will reduce weight too
mjr46 is offline
Old 05-10-2008, 02:10 PM
gmkiller50
gmkiller50's Avatar
you could shave off about 70lb if you swap k-members with aftermarket k-members kits
gmkiller50 is offline
Old 05-10-2008, 02:24 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
Remove that big hunk of cast iron off the rear end center section.
JD1969 is offline
Old 05-10-2008, 05:00 PM
stang8689
stang8689's Avatar
Remove the spare tire and padding.Aluminum heads, radiator, driveshaft, and flywheel all save weight. The tubular K kit is a huge savior.
stang8689 is offline
Old 05-11-2008, 02:20 PM
tinman
tinman's Avatar
Get manual steering set-up and remove HVAC system from car.
Your car could end up like mine, 2840#,'84 hatchback if you do things right. BTW, 28403 is with a 190# of me in the car.
I got almost 325# out of it after I bought it and it already had some of the wieght out of it........
tinman is offline
Old 05-11-2008, 04:48 PM
302army187
302army187's Avatar
ORIGINAL: tinman
all i have to say is WOW
i have a goal of 3000lbs with me OUT of the car, for a 89 lx vert aod........ (k member, alum heads, t5swap to start)
302army187 is offline
Old 05-11-2008, 05:31 PM
OneFine89Mustang
OneFine89Mustang's Avatar
not sure if your running ac or not but you could loose the ac compressor and the condensor and the smog pump if your not running emissions
OneFine89Mustang is offline
Old 05-11-2008, 06:19 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
ORIGINAL: 302army187
ORIGINAL: tinman
If you didn't know the old 4 eyed cars are a bit lighter than the aero cars. My 83 hatch is supposed to weight like 2700 from the factory dry from what I have read. You also have a vert and its an aod. That doesn't help you at all.
projectresto83 is offline
Quick Reply: Weight Reduction
