THR 347 in my 94 GT
Old May 16, 2008 | 03:29 PM
  #21
ruger311's Avatar
ruger311
Default RE: THR 347 in my 94 GT
if you arent planning on adding much nitrous or a blower then the stock block will be fine but you need to ask yourself if you are really planning on keeping it "stock 347" or in the back of your mind are you lying to yourself like i did??
if you are going to spray it you could spray prolly a 100shot on a stock block 347 but anything else need to get an aftermarket block
you might look into a big bore 347 kit to keep rod stress down too
you can get a regular 347 rotating assembly for around $950 and then they are prolly gettin that TF stuff for $1800 or so for heads and cam, magnaflux and machining prolly costing you $1000 from them, plus balancing
just take your time dont jump into anything you arent ready for
Old May 16, 2008 | 03:30 PM
  #22
ruger311's Avatar
ruger311
$4000 not that bad though
Old May 16, 2008 | 05:01 PM
  #23
1BIGMOFO's Avatar
1BIGMOFO
Thats what I was thinking, it will save a ton of headaches. Pay the 4 grand. pull my engine and install the new one. I wont have to worrk about installing the cam or timing chain etc etc itll come all ready to install..
I plan to have all of my brackets and accessories powdercoated so I would probably pull the car apart a week in advance and install the entire engine in a day or so.
Makes sence right?
The engine from THR has a 3 week turn around so I could have the car prepped and ready by then with no issues..
Old May 16, 2008 | 05:03 PM
  #24
1BIGMOFO's Avatar
1BIGMOFO
I called to speak with Brian at THR today at 9am and still have not had a response. I dont know what kind of feeling that gives me!
He seems very knowledgeable etc. I dont kknow what to do.
Old May 18, 2008 | 08:30 AM
  #25
1BIGMOFO's Avatar
1BIGMOFO
Heads are Twisted Wedge track heat 60cc 172 intake 202 valve 1/6 exhaust valve
compression is 10.29 - 1
crank is cast
rods are h beam probe forged
pistons are flat top probe forged
tfs push rods
rr's and rings are all trick flow
lifters are ford racing
bearings are ford racing
all felpro gaskets
stage 2 cam made by trick flow 542 / 563
timing set is double roller trick flow
oil pump included
water pump included
hd oil pump rod
28 oz balancer for $100 extra
28oz flywheel $100.00 extra
All for $4100.00 what do you think??
What else do I ask???
Old May 18, 2008 | 09:38 PM
  #26
ruger311's Avatar
ruger311
dont have a lot of time right now will hit you up in the morning,
Old May 19, 2008 | 06:36 AM
  #27
1BIGMOFO's Avatar
1BIGMOFO
Ruger,
thanks for taking the time to get with me on this. I am expecting to make a decition on what im buying this week. I am planning on taking the majority of the parts off the car this coming weekend. I am going to paint all of my accessiries and brackets this weekend with POR15. Itll match my upper / lower performer II intake perfectly.
If you hae any suggestions for me please let me know!
Old May 19, 2008 | 08:35 AM
  #28
Jrichber95GTS's Avatar
Jrichber95GTS
Sorry i didnt clear that up i do atm have a 347 i put the24# in when i redid my motor not exactly sure what hp im runnin takin it to a dyno in a month or so to get a chip burned for it and see my exact numbers
Old May 19, 2008 | 08:38 AM
  #29
ruger311's Avatar
ruger311
you will need bigger than 24#ers for a 347, you probably wasted your money on those,
strong i will reply to your questions in a bit, gotta do some work first
24ers prolly good to 310HP
  #30
ruger311's Avatar
ruger311
crank
