EGR?
Old 05-16-2008, 08:58 PM
94GTPRO5.0
94GTPRO5.0's Avatar
Default EGR?
Does anyone know if you do away with your EGR on a 94 gt, will it cause the car not idle right? I done away with my by just unplugging it and blocking it off on the intake, and the car don't want to idle right at all. I order a EGR Eliminator Plug from (RJM) that plugs into the wiring harness. It say in the description that it could cause your idle to surge if you don't have the EGR Valve Position Sensor Eliminator. Has anyone had this same problem/or know anyone that has?
94GTPRO5.0 is offline
Old 05-16-2008, 09:06 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: EGR?
removing egr valve should not affect idle at all..it can cause idle roughness if the pintle is partially open at idle
mjr46 is offline
Old 05-16-2008, 09:08 PM
94GTPRO5.0
94GTPRO5.0's Avatar
Default RE: EGR?
so the only thing i would be getting is a CEL on by just unplugging it?
Old 05-16-2008, 09:11 PM
mjr46
mjr46's Avatar
Default RE: EGR?
the eec iv I believe automatically deletes egr operation when probs occur or it is removed..so you should be fine
mjr46 is offline
Old 05-17-2008, 01:11 PM
94GTPRO5.0
94GTPRO5.0's Avatar
Default RE: EGR?
So I'm still screwed about my idle problem?
I have done everything to try to fix it and still cant get it right.
Old 05-17-2008, 01:57 PM
Joel5.0
Joel5.0's Avatar
Default RE: EGR?
ORIGINAL: 94GTPRO5.0
Checking your previous posts, I see that you have a SN95 but the codes you post are the 2-digit format....... was your '94 fitted with a ECM from a fox?
Joel5.0 is offline
ShaneB26154
35
03-04-2021 04:05 AM
TfcCDR
09-14-2015 12:08 PM
J.casone400
09-03-2015 04:43 PM
J.casone400
08-25-2015 12:19 PM
Quick Reply: EGR?
