MSD digital Window Switch...
Alright I decided to get fancy and get a nitrous kit off of a fellow member here. I have everything else hooked up except for the digital window switch. I have the power/ground/tach all done but do I just use the yellow wire on my micro switch for normally open or just use the gray wire for normally closed? I know it probly sounds stupid but Sucks not having any direction! thanks in advance
RE: MSD digital Window Switch...
You want the normally closed wire... that way no power is getting to your soleniod until you are in the window you program into it (say, 3000 to 6000 RPM)... then it will come on. That's how I have mine wired up and programmed.
alright so I Run the normally closed wire off the box on the one end of the micro switch, then the other wires go to the silenoids and fun stuff alrightt!. Now I can throw a switch in the wire going from the box to the micro switch right for I can disarm the system?
