New member with electrical issues!!!!!!
RE: New member with electrical issues!!!!!!
heck if you have a donor car.. use as much of that as you can....not everything on the car is transferable as you obviously can tell by looking at it but alot can be used.. like tranny if it's a t-5.. with the swap of a input shaft or if you use a fox bellhousing with fox t-5 then I believe you can mod cross member and use a spacer on the driveshaft flange to make up the shorter length of the fox bellhousing..anyway just some ideas
do not use the **** from the fox. get the proper SN pieces... they shouldnt be very hard to find.... There is a junkyard about 25 minutes from my house that has about 5 Sn 5.0's in it
My motto is.... di it right, or don't do it at all
ORIGINAL: AdderMk2
LivingInThePast
09-16-2015 12:20 PM
TfcCDR
09-14-2015 12:08 PM
