Rear end change Q
Old 06-09-2008, 09:45 AM
hillbilly pony
hillbilly pony's Avatar
Default Rear end change Q
I am swaping rear ends in my 87 and my question is for anyone who has basicallya dedicated race car. the rear i am puting in is from a car that had front end fire damage and the e-brake lines were cut to speed the removal process. is it a big deal if i didnt put it back on? also what is the easiest way to re attach the brake line on top of the Diff. yes i forgot about it and broke it getting it out.
hillbilly pony is offline
Old 06-09-2008, 10:04 AM
sultan68
sultan68's Avatar
Default RE: Rear end change Q
if i understood the question correctly about the brake lines..you may be able to use the brake line from your old rear end
sultan68 is offline
Old 06-09-2008, 10:36 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
are you talking about the break line that goes into the distribution block or did you break the hard lines that attaches into the brake cylinder thing?
FivePointOhh is offline
Old 06-09-2008, 10:37 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
just buy a new rear brake hose if that's the one that got damaged
mjr46 is offline
Old 06-09-2008, 08:11 PM
hillbilly pony
Yeah i broke the flexable line that goes from the body to the Diff. I just could see an easy way to fix it with the rear end in the car. I was guessing i hook up the lowers and jack it up some and go with it.
Old 06-09-2008, 09:31 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
You should be easily accesable with the rear in the car. Any piece you need can be bought new so it shouldn't be that hard. Why did you swap the rear end out???? With you having an automatic you won't need your e-brake so you can leave it out. It will drop a few pounds off the car too. If you don't know where to get the new parts check out www.latemodelrestoration.com
projectresto83 is offline
movielover40
08-27-2015 10:13 PM
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
92 5.0stang
08-13-2015 06:46 AM
PearlGenPu
08-12-2015 01:57 PM
Quick Reply: Rear end change Q
