Engine Miss!
Engine Miss!
Whats up guys...what would cause my 5.0 to miss only when it goes over a small bump in the road..what happens is that the engine misses and the rpm flicker...I have no idea..ill apreciate any suggestions..thnx
RE: Engine Miss!
make sure all wires are pressed on the cap and coil and plug ends tight/ snapped in place......there could also be a loos connection on one of the primary ignition components such as coil, tfi harness, stator in dizzy ect ect..... check all ignition system related wiring and or connections
RE: Engine Miss!
ORIGINAL: mjr46
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
