tps sensor and explorer TB
I installed an explorer TB on my 91 GT and swapped the stock stang TPS right onto the explorer one w/o modification. I read that the bolt holes would need to be widened but it slipped on perfectly. How do I know if my tps is working correctly?
I ask because my idle is a bit funny. It idles at 1100rpm for a while then bottoms out at 700 eventually. I also put in a new h/c/i as well but don't think my idle should be taking so long so bottom out.
RE: tps sensor and explorer TB
Anywhere from .7 to 1.1 closed throttle output voltage will be fine. If you want to check if the system is working with a TPS related failure, run the DIY KOEO/KOER/Cylinder Balance Self-Test and LUK.
jwog666
12-27-2021 08:09 PM
TfcCDR
09-14-2015 12:08 PM
