how to set base timing
I moved my dist. the other while changing the thermostat, having trouble with the bottom bolt on it. I tried to mark it and set it back as close as I could. I have never set base timing, do you need to connect or disconnect anything before shooting it with a light. Also what is recomended 10 btdc. Running a super charger.
thanks
mat
thanks
mat
depends on boost level you are running what desired base is..if you have a boost retard that'd help out but 8-10 degrees max and you need to pull the spout connector and then you can set base timing which will require the use of a timing light
Good link Joel, thanks that will help a lot.
Mjr46 I am running a boost retard setup with an adjustment **** inside the car, not really sure how toset this though.I dont have any information on it and this caris anew purchase to me. It is currently set in the middle range of the **** now, not sure if this is right or not. Anyone have any advise on how to set this???
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
SterlingStunner
5.0L V8 Technical Discussions
Sep 4, 2015 06:28 AM
