hunting idle..map sensor??
Old Jul 1, 2008 | 08:39 PM
saocore88's Avatar
saocore88
Default hunting idle..map sensor??
i posted previously the problem with the hunting idle for my 925.0. i replaced the iac and the problem still occurs. i was told to check for a vacuum leak from the map sensor vacuum lines from the upper or lower plenum. does anyone know where i can find the lines and what should i look for to know if they are bad and that is the problem?
Old Jul 1, 2008 | 08:51 PM
Joel5.0's Avatar
Joel5.0
Default RE: hunting idle..map sensor??
If your car is a '89+........ the MAP sensor does not use a vacuum hose, it's a BP sensor..... suggest to check the system for failure codes, run the DIY KOEO/KOER/Cylinder Balance Self-Test and verify what might be wrong with the EEC system. LUK
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
TfcCDR
Sep 14, 2015 12:08 PM
