Wiring issues
Old 07-03-2008, 03:13 PM
F350Dually
F350Dually's Avatar
Default Wiring issues
well i bought a 88 gt that needs a lot of work so i figured i would start with the small stuff, anywho i cant get the fuel gauge and power mirrors to work, mirrors dont make any noise when i push the buttons any help would be great, also hatch release doesnt work
F350Dually is offline
Old 07-03-2008, 07:18 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Wiring issues
check fuses if not test switches
mjr46 is offline
Old 07-04-2008, 01:48 PM
F350Dually
F350Dually's Avatar
fuses were blown but i replaced them and still got nothin, how do i test the switches
Old 07-05-2008, 09:30 PM
F350Dually
F350Dually's Avatar
any one?
Old 07-14-2008, 02:23 PM
F350Dually
F350Dually's Avatar
damn no one can help me?
Old 07-14-2008, 03:05 PM
brentloftis
brentloftis's Avatar
ORIGINAL: F350Dually
well i bought a 88 gt that needs a lot of work so i figured i would start with the small stuff, anywho i can get the fuel gauge and power mirrors to work, mirrors dont make any noise when i push the buttons any help would be great, also hatch release doesnt work
Just a shot in the dark you forgot the "t" above? To test the switch for the mirrors you will need a multimeter to test continuity between the leads\ wires. Here is a electric diagram to help you on your way.
For the fuel gauge:
Fuel Tank Analog Gauge
[*]Disconnect wiring harness connector at sending unit and connect ohmmeter between ground terminal and resistor terminal on sending unit.[*]Meter should read 8-86 ohms. If reading shows no continuity (infinite reading), check ground connection to tank gauge.[*]If ground is satisfactory, but reading is not within specification, tank unit is defective.[*]If reading is within specification, remove fuel tank gauge from vehicle and connect ohmmeter between resistor terminal and ground terminal (metal housing on single terminal units).[*]Observe meter while slowly moving float rod between empty and full stops. Meter should read 60-86 ohms at empty stop and 8-12 ohms at full stop. Change in readings should be smooth, without hesitation or jumping.[*]If tank unit fails to operate as outlined, unit is defective. Before installing fuel tank gauge, connect wiring harness connector to gauge and move float rod from empty to full position with ignition key in ON position. If dash gauge reading is incorrect, check IVR and dash gauge. If system tests prove satisfactory, but system still does not operate correctly, check that tank gauge rod is not bent or binding and that float is not damaged, loose or filled with fuel. [/ol]
brentloftis is offline
2007StangV6
01-28-2016 06:09 PM
Ford_Dude
09-15-2015 03:25 PM
jaiidutch
09-14-2015 10:29 AM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Wiring issues
