code 91 problems
Old Jul 10, 2008 | 07:43 PM
93 LX FiveO's Avatar
93 LX FiveO
Default RE: code 91 problems
i took each 02 sensor out and cleaned+re-installed.
also cleaned off the connections and wires
took the EGR off and cleaned that as well and sprayed intake cleaner into the MAF and TB.
reset codes, and re-scanned. now only get 91 and 44.
the exhaust is tight. why would my 02 sensor just all of a sudden go bad?
ive had a code in the past regaurding a bad fuel pump circuit and suddenly disappeared.
Old Jul 10, 2008 | 08:38 PM
Joel5.0's Avatar
Joel5.0
FYI..... I've had to re-replace brand new units after finding out they were producing (-) voltage. If they were bought less than a year ago, and you still have the invoice/ticket..... that one is still under warranty. To be 200% sure it's a bad O2 sensor, you can also swap them from sides, if a code 41 shows afterwards (failure code following the O2 suspect)...... that sensor is defective. LUK.
Old Jul 11, 2008 | 09:30 PM
93 LX FiveO
alrite heres the update..
i took the sensors out again and they were really black, as if i was running too rich.
cleaned em off and switched the sensors.
i was able to get some turns out of the collector bolts and all is tight.
still getting code 91 and 44, saying bank 1 is lean???
so ive pretty much ruled out a bad sensor and exhaust leak. next step would be to check the wiring but i dont even know where to begin.
how can i test if the sensor is switching/opening the circuit?
Old Jul 12, 2008 | 06:34 AM
Joel5.0's Avatar
Joel5.0
Start with....
Old Jul 13, 2008 | 05:54 PM
93 LX FiveO
ok i did the first test in the table and got .2-.3 volts on both sensors
i got confused on the other tests and wasnt sure how to create a vaccum leak with the key off.
i pulled all the plugs and every tip is white. car is running like dog crap.
Jb145700
Aug 21, 2022 06:37 AM
Golfsito
Oct 6, 2015 11:02 AM
TfcCDR
Sep 14, 2015 12:08 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
zanemoseley
Sep 6, 2015 12:58 PM
