No crank after AOD-T5 conv.
Old Jul 11, 2008 | 04:31 PM
jagman454's Avatar
jagman454
Default No crank after AOD-T5 conv.
Ok, so I got 4 wires that are suppose to go to my T5, I hook 2 of the purple ones together and my tail lights light up so I know where those go, but the other two, (one red, one white) must be the Neutral safty switch right? So I hooked them both up together and when I turn the key I hear one "click" noise and then my car goes compeletly dead, I have to dissconnect the battery and let it sit for a second before it will even use the power, and if I try to crank without hooking the redwire, and the white wire together I just get a "no crank", nothing.....does anyone know whats going on?
Old Jul 11, 2008 | 04:33 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: No crank after AOD-T5 conv.
you might have a short now if you guess the first few times by touching the wrong wires together to figure out the orientation
Old Jul 11, 2008 | 04:57 PM
jagman454's Avatar
jagman454
So what do I do now?
Old Jul 11, 2008 | 06:15 PM
jagman454's Avatar
jagman454
I found out that the "clicking" noise is comming from the solenoid.....???
Old Jul 11, 2008 | 07:16 PM
AdderMk2's Avatar
AdderMk2
Banned
the single click is indicative of a bad ground or lack of power. double check the power wires on the starter and see if it's getting a good ground.
Old Jul 12, 2008 | 02:33 AM
mxrider426's Avatar
mxrider426
Check ground strap too
svfetter
Oct 5, 2015 11:39 AM
jessicarabbit
Sep 25, 2015 12:41 PM
SteelerNation82
Sep 16, 2015 07:11 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
Wombatnation
Sep 13, 2015 09:16 PM
