installing gauges
for the oil and water if you dont need to maintain the function of the stock oil and water guages just find the sending units for each on the block and remove the stock units and replace with yours. as for volt ive v=nvr used it so i dont know how to
The water and oil should have come with their own sending units. More than likely they're not compatable with the factory sending units. The volt meter, you're on your own. I believe they'renormally wired into the alternator harness, or can be wired into the solenoid harness?
Galactic
Apr 29, 2019 02:56 PM
