Injectors to use with nitrous?
My 88GT has:
cold air intake
edelbrock upper/lower intake
bbk headers
bbk o/r H-pipe
flowmasters
Full MSD ignition with 6AL box and 2 step
B-303 cam
gt-40 heads
1.7 roller rockers
70mm TB
underdrive pullies
My injectors have a light blue top...awhile ago i seen a thread that showed all the injectors and what #'s they were...anybody got a link to that page? And should my injectors i have nowbe good with a wet 100 shot of spray?
cold air intake
bbk headers
bbk o/r H-pipe
flowmasters
B-303 cam
gt-40 heads
1.7 roller rockers
70mm TB
underdrive pullies
RE: Injectors to use with nitrous?
light blue are 24# ones. I am spraying a dry shot on my h/c/i with the same injectors. If you want to go wet shot like you said your injectors will be fine bec u will be spraying the extra fuel threw the fuel line u will have to run for the wet kit
https://mustangforums.com/m_967788/tm.htm
...and Bikeboy is right. If you're spraying wet, you're fine with what you have. Hell, you're fine spraying 100 dry for that matter.
Thanks guys. Now with the wet kit do i have to run a new fuel line from the tank or is there an easier way to do it? I think i read somewhere where i could tap into my fuel rail where my fuel pressure gauge goes?
