map light issue
RE: map light issue
yea i took it out and nothing is corroded i was actually at the junk yard and found one in a mustang the same model year as mine so i just picked it up charger me a buck for it. that one looks very clean as well i tried both and still nothing so i guess i gotta test everything around it
RE: map light issue
ORIGINAL: mattdel
sad to say, but you wont find anything more than generic help here. thats custom, not factory.
those style lights should auto-power-on when you pull it down from the parked position. i can only assume that either that switch is dead, or there is no power going into it to begin with.
start taking it apart and do some testing.
RE: map light issue
I've had those map lights in two of my cars... in one of them, the switch became corroded or just bad. But, if you said you replaced the whole unit with a junk yard part, I would check to see if you are getting power to the leads... a multimeter will make quick work of that. If you are getting power, then you know there's something wrong with both. If you aren't then you can check the fuses and if that's okay, you can try to trace back the wiring and look for a ground or bad wire.
RE: map light issue
+1 on mattdel wasting post space and being a noob. Those lights are not custom haha I have one also. but yea anyway I would take it apart and check wires I guess, but mostly wanted to say mattdel...... is a ROOK! I hate it when people waste post space with nothing helpful
RE: map light issue
ORIGINAL: FinnishMafia89
Not to mention that the 3 of these cars I've owned never had it.
So stop calling people rook, and noob. You have no idea who I am.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
zanemoseley
09-06-2015 12:58 PM
