TUBULAR FRONT END-COMMENTS PLEASE
THIS IS FOR 93 GT MUSTANG . IS TUBULAR FRONT END WORTH THE PRICE? I KNOW IT REDUCES WEIGHT. CAN I STILL RUN LARGE TIRES ON FRONT, DOES THE CAR STILL RIDE / DRIVE GOOD? WHERE IS A GOOD PLACE TO BUY ONE, WHAT KIND TO BUY? PLEASE LEAVE YOUR OPINION. THANKS.
RE: TUBULAR FRONT END-COMMENTS PLEASE
I HAVE SOME OF THE OTHER THINGS. JUST WANDERING ABOUT THE TUBULAR FRONT END . A GOOD BUY IN A QA1 IS AVAILABLE UNTIL 5/16/05. I NEED MORE INPUT/ADVICE. THIS SURE DOES LOOK NEAT AND CLEAN JUST LOOKING AT IT. THANKS FOR THE ADVICE. KEEP IT COMING.
well it's a good way to go if you have the $$$$$ you'll also need coil overs and camber plates this will make the front end fully adjustable and you can change ride hieghts...works greta with large tires..the main thing you have to decide is spring rate
youll need some stiff springs ..i got 200 lbs on ft of mine ..i like heres some pics 4 y
[IMG]local://upfiles/10419/383F353591E24B939AF33671EDB3D512.jpg[/IMG]
[IMG]local://upfiles/10419/601F76BA0B1B4E9AB2E4228636CA65E1.jpg[/IMG]
you will need some 300 or 350 lbs ers ..for street corner driving, thats all the pics i got ..i got ground pounder setup with lower arms with coil over fronts and bump steer kit ..was around 1000 for every thing..camber plates too. i hope this helps...
[IMG]local://upfiles/10419/4846B59D16384646B172F20FF5B308C6.jpg[/IMG]
[IMG]local://upfiles/10419/193DE726977644AA8A17C8C58A24BEFF.jpg[/IMG]
breaking
10-02-2015 01:27 PM
