TPS question
TPS question
ok on my 92 lx 5.0. my car wont start. it started fine earlier in the day. then i got home to check the oil cause i got a rear main seal problem. i notice that i was 2 quarts low. so then i noticed that one screw was missing on the tps. stupid me turned it. now it just keeps on turning. so i take it off and notice that the 2 teeth or what ever you call them kind of rounded out. so the throttle is not cathing on the teeth to make the tps to work. could this cause the car just to crank and not turn over or could i have another problem. to tell you the truth this is just a project car and right now im not worried about perfomance. i just want it to run right first. cause i think tps cause it worked right before i twisted it off and rounded out the teeth or broke them. and i just cleaned the IAC, egr and TB. i havent gotten to the maf yet. i need that tool first. any suggestions.
RE: TPS question
get your tps lined up as well as u can and find a way to keep it in place with tape or something crank it over and see if it starts, for information on how to adjust your tps to the right setting theres a thread on here somewhere that says how to adjust it
RE: TPS question
thanks guys for the help. i just needed a new TPS. dint start at first. so i tried diconnecting the neg. batter cable for 15 mins. put it back on and it started right up. and the tps does have a moving part. thanks again.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
