T5 Cluster Gear
Old 09-05-2008, 04:46 PM
jagman454
jagman454's Avatar
Default T5 Cluster Gear
Will a Cluster gear out of a manual 1996 v6 mustang fit into a T5 from a 90 5.0 notch?
thanks!
jagman454 is offline
Old 09-07-2008, 10:15 PM
holyshift
holyshift's Avatar
Wink
Dont know if the cluster will but if you get the tranny and the correct bellhousing for that tranny it works. I ran one for 3 years and had no issues until i added the nasty clutch combo that i have for sale right now...haha. I think there geared different to, my car picked up like 3-4 tenths when i switched from my stock broke one to this one....But really, i dont see why not, contact a ford mechanic at a dealership or something
holyshift is offline
Old 09-08-2008, 09:00 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
thanks!
no ratios are different
mjr46 is offline
Old 09-08-2008, 12:29 PM
jagman454
jagman454's Avatar
I ask this because, i did it. When I rebuilt my trans I put a gear cluster from a 96 v6 T5 in my 90 T5, it worked well for a least 2 months but now its getting stuck in reverse and ever since I've rebuilt i Get a vibration at 80mph......
Old 09-08-2008, 08:08 PM
holyshift
holyshift's Avatar
well what would cause me to pick up 3 tenths?????curious to know
Old 09-10-2008, 08:21 PM
jagman454
jagman454's Avatar
does the cluster gear sound like my problem? before I rebuilt the trans someone told me that all of the T5 internals are interchangeable... hence the reason why I used the cluster gear....if I replace the cluster gear do you think this will fix my problem?
really need help on this thanks....
Old 09-10-2008, 10:08 PM
mjr46
mjr46's Avatar
it could fix it but endplay and proper shim in the retainer should be used also
mjr46 is offline
Old 09-12-2008, 05:15 PM
jagman454
jagman454's Avatar
yea, I used a friends dial indicator and I to the best of my knowledge I did the shim part right... idk... I guess the only way to know for sure is to take the thing back out again...
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: T5 Cluster Gear
