PCV problem
Old Sep 17, 2008 | 06:45 PM
fordboyyfm's Avatar
fordboyyfm
take the pcv off and just runn breathers on the valve cover, you want want the oil going into the intake, its like it cuts down the octane of your fuel in half and your running lean.
the rings in your new motor are prob not set in yet, takes a while for some of them so right now you have a little more blow by and thats why the oil is getting pushed through the valve cover.
Old Sep 18, 2008 | 12:09 AM
89coupe's Avatar
89coupe
anyone else got any ideas
Old Sep 18, 2008 | 01:28 AM
dudeboy's Avatar
dudeboy
Check this for some background info...
http://www.freewebs.com/vristang/pcv...trolissues.htm
I haven't seen the motor, and I don't know for sure what your pcv setup really is,
but my opinion is that you need to increase the VOLUME that the pcv system can flow, which will decrease the velocity of crankcase gasses leaving the lifter valley.
jason
Old Sep 18, 2008 | 01:31 AM
dudeboy's Avatar
dudeboy
cuts the effective octane in half, and makes the AFR lean?
Is the lean AFR supposed to be caused by the octane drop?
Care to back some of that up? Any documentation to support this?
Sounds like internet hogwash to me,
jason
Old Sep 18, 2008 | 12:42 PM
89coupe's Avatar
89coupe
i am using the vacuum setup that holley recommends and the line on the pcv valve to intake is 3/8's hose.
Seanam
Oct 4, 2015 10:15 AM
Ipaman
Sep 22, 2015 07:01 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
